Ronin807
It looks like you may have to "clock" your driver side (atleast) LED bulb....I think it might be in upside downGlad I Found this thread. New guy here but on just about every other forum. Haha
I bought a set of Alpharex G2 Pros. 2012 Ram 2500. Put Hikari Ultras in the high and low beams... put it all together, could only get one high beam and one low beam to work. All DRL and turn signals function well. I have not programmed via alphaobd yet. If I do, will these Hikari Ultras work as they should? The H7s they came with are pathetically dim.
Also- adjustment. Theyre all out of whack. Low beams are opposite of high beams so curious how that can be settled? Highs are super tight pattern. Too tight. Almost worthless. Lows are exponentially more out of adjustment compared to the high beams. Any input? They're brand new..pics attached. First two are low beams (in cab and out) second two are high beams (in cab and out)
Sent from my SM-G975U using Tapatalk
