b5rider
- Joined
- May 21, 2016
- Posts
- 118
- Reaction score
- 17
- Ram Year
- 2016
- Engine
- hemi 5.7
Hi,
I have a 2016 1500 with the base system with the add-on navigation (not built in)
I added some Focal 6.5 components to the front and noticed they have NO low end, even when I turn the volume up as high as they can take.
I want to add a 4 channel amp to run the fronts and rears. I do not want any subs.
What is the best way to get a full range signal to the front and rear speakers?
I am Ok with adding an amp, if needed, but is there any product that will change the signal to full range using the stock HU's signal?
If you have any experience, please reply with brand and model number of electronics used.
Also, I am a cheap *******, so please try and suggest something reasonably priced.
Thanks
Thanks
