Bedlinner on side of truck
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
See post #22 on page 3
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
USE GOOD BEDLINER. i used cheap **** and it flaked off and didnt last. its easy to do and helps prevent rust and rock chips and scratches so its a great idea... just dont cheap out.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I'm tossing around the idea of having a shop spray on line-x or rhino lining so I only have to do it once.
but I have to do something about my drivers door because it's has some bad rust and the paint is bubbling so I csnt jusy put the liner right over the rust correct?
Or will the liner so the rust?
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
weld a patch panel over any holes, dont spray it on use a roller so you can get a thicker coat.
2011 Ram 1500
The problem I have with that idea is it looks great at 1st but after a few years in the sun, the bed liner starts to fade.
2011 Ram 1500
Did you bed liner your whole truck yourself or did a shop?
dapepper9
Iowa/Nebraska Border
5.9L V8
Scorpion liner is good too. Guy that's had a few posts on here did his with it and after 3 years tne red still looks brand new. He did red top black bottom 2 tone full liner. Looks great actually. Can't remember his username
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Bump for any ideas of how to take care of the rust issue then bedlinnern
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
I would scrub off all the rust with a soft grinder or metal brush on a drill head. When you're done the rust will be gone and hopefully you don't have a rust through holes. Clean out the bed and get rid of all the rust pariticles and paint the effected bare areas with a zinc chromate primer paint (I'd locate the paint first). Zinc chromate was used in aircraft to prevent rust. It's toxic so as soon as it dries apply the bedliner coating over it. Make it nice and thick in those rust areas.
This is roll on
https://www.rustoleum.com/en/produc...yd-coatings/7400-system-zinc-chromate-primers
This is spray on (use a mask)
Moeller Marine Zinc Chromate Spray Primer
kealiher2004
How about sandblasting the rust? Fairly easy just messy, but looks good and leaves smooth surface.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
My concern is that after I sand off the rust, there may end up being holes or pieces of the driver door that are now missing because they were rusted through..
is my only option a new door? :(
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
If the frame is okay you can patch it. If the frame has mils issues you can patch it.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
You talking about bondo? I told myself that stuff would never touch my vehicle :puke:
JustinRam1500
