Best way to re-adhere the rubber strips on top of the cab that wrap down to the rear window..
John Jensen
San Diego County
Ecodiesel
Disclaimer: 5200 can be applied underwater and care should be made not to create air pockets inside as these may trap contaminates and or moisture.
In general it stays in a flexible state.
its best to use small tubes because once opened the shelve life is only three to five days at best, you can cut open the tube and use a spatula type tool for application if the neck and cap (after opening) become fused together.
Once you open it, store it in the freezer, it will keep nearly forever. I have some that's been in the freezer for ten years or more, and it's still good.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Because before you edited your post you quoted mine LMAO
I thought you assumed because I did quote your post I was directly addressing you where I was not and only addressing your concerns to others that are contributing… so I removed it not to confuse anyone
but I bet you didn’t know about the freezer…
HemiLonestar
MD
Nope, but that's literally because I've never had to store any; every tube got used completely lol.
corneileous
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Well fellas, that regular ole weatherstripping cement I bought almost a week ago apparently did the trick. It’s holding really well.
