Bilsteins and 2017 1500
Jesse1031
Clovis, Ca
Guys I need some help on this. Local shop told me that I cant run the bilsteins on my 2017 sport. Apparently they dont make them. Issues with the UCA. I can only do a 1.5" spacer kit which really is not what I was looking at. Has anyone done bilsteins on their 17' or is there some truth to what this guy has told me.
LumberJakl
Calgary, AB
'17 Sport QC
5.7L 4x4
Lol... sorry but find a new mechanic / shop. I just put bilsteins on my new 2017 (not even 100miles on the odometer ) and it fits in perfectly . I think he was trying to say is your upper arms ball joint over time will wear out faster , but there are many people still running their stock upper arms with bilsteins with no issues.
Jesse1031
Jesse1031
Clovis, Ca
That kinda what I was figuring. I didnt think they changed much, if anything between 16' and 17'.
RoadKing
Ga
2022 Bighorn
HEMI 5.7
You could always contact Bilstein. They will verify for you.
Syntec
Eh?
H5.7
Bils at 2.1 should be no issue. Lots of people running that setup including myself
Bils at 2.8 where one would recommend upgrading UCA's
Good luck
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
As the others have already stated, there's no change in the front suspension between 2013 and 2017 1500's. So they'll bolt up no problem.
You don't need new UCA's with the Bilsteins either as they limit the front suspension travel to OEM specs. It's the overextension of the front suspension that you get with spacer type leveling kits that cause the ball joints to pop out.
Jesse1031
Jesse1031
Clovis, Ca
Thanks for the info. Now its just a matter of whether to level or just drop the cash and lift it.
Schu3507
V8
I did rough country level kit. Feels like factory ride, seriously. However I did same day I did wheels and tires. I also don't jump truck, occasionally go through mud but not hard core off roading, no idea if makes diff?
Fanta1500
Albany NY
Yeah like syntec said, 2.1 is where you'll be fine and 2.8 is where you should upgrade the UCA. Some guys don't have issues doing 2.8 on stock UCA but it's not worth the risk for .7 more unless you have mevoteck or zone UCA. If you have the money I'd do the zones
