I think if we take some of our scientific ideas/theories/guesses together, we come up with:
shortage of lubrication to the back (firewall side of engine) of the cam/lifters
too thin recommended oil from factory
oil thins out as you put more miles on it
Add all of those up and now we have a case for: thicker oil with a higher film strength that shears down the least and a tendency towards a shorter OCI than we expect the oil can handle
5-20 is a bad start to begin with, granted it wont shear down (where would it go, a 10? lol) but even the brand-new-oil viscosity might be too low. Some 30 weights shear down to very low 30 weight or even a high 20 weight...maybe a bit better, but still probably not ideal. That leaves 30 weights that either dont shear at all, or very little, or 30 weights that start "heavy" and even after shearing are still in the mid-range of 30 weight rating.
And on top of all of that, do not run overly extended OCIs. Luckily in my case I never get to a lot of miles in an OCI, I change out after 6 months and maybe have 4K miles on the oil. Could I go longer? Of course, but Id still need to change the oil again in the year anyway, so I might as well change early rather than late.
