cc rider
- Joined
- Dec 10, 2013
- Posts
- 1,174
- Reaction score
- 202
- Location
- Western NY
- Ram Year
- 2015
- Engine
- 6.4 Hemi
Your the first one I've seen complain with a 14 truck. I know yours is a different part number.
i have found something interesting.. with my 12" brakes the estimated amperage to function per axle is 8.4, so if we take 16.8 (since I have a tandem axle) and multiply it by the voltage I am seeing we get ~122.64 watts (roughly).. I bet you anything these brake controllers have a built in wattage limitation that means a maximum duty cycle of 120W which at 16.8A we get 7.3V....
Those are stout findings. Maybe run the gizmo around to a few Ram dealerships on the weekend while folks are shopping? "Hello friend, I'm just a concerned citizen that would like to inform you about the purchase yer contemplating." Hit these sons 'o ******* in the coin purse and I bet you find a sympathetic ear. Also may be time to talk to the local State Transport Authority sub-station about yer recent findings. This is becoming damn near epidemic. Kick ass and leave a footprint, Boss.Welcome and thanks for sharing your results, the more folks we get, well...
I built a trailer brake simulator, I used the armature of a 12 volt dc motor for the inductor, and a 6 ohm 5 watt resister for the load. If anyone would like to build one, just use one or more electro-magnets from an electric brake. Available from your local trailer parts store.
The first thing I did was to connect my 2013 RAM to my Montana 3790RD RV, with the ITBM at 100% (manual slider) I measured 11.96 volts, 12.6 amps, and a duty cycle of 97%.
Next I connected the 2015 RAM to the Montana, 100% braking by the manual slider, 6.96 volts, 66% duty cycle, didn't bother with the amps because it is meaningless at this point. Then I attached the simulator to the 2015 RAM, got the same measurements. Took the simulator to the 2013 RAM and matched the results I saw when attached to the Montana. Good, I have a simulator I can use to look at other RAMs.
Lucky for me, I work on a campus that houses well over 3,000 employees. In my group I located a few 2015 RAMs with the ITBM. Using my simulator I found all the 2015s unable to provide full braking output. The highest measured was 73% duty cycle. I found two 2014s, they were able to put out the full duty cycle like my 2013 RAM.
My Montana has twin Dexter 7k pound axles. Dexter told me to expect about three amps per brake at 12 volts. Using my Prodigy P2 in my 2015 RAM, I made a few hard stops and found the Dexter's need 10.5 volts to provide hard braking. The seven volts from the 2015 ITBM just isn't cutting it.
I thought the real issue would be proving the issue with the ITBM but it isn't, the real problem is getting someone in a position than can take action to listen.
I posted about this issue on the "other" forum too. We need to get as many owners as possible to file a complaint/take action. Unfortunately, there haven't been many so far. I'm going to be doing it tonight or tomorrow
actually what might be a better option would be to get a youtube video up... and start trying to get it to go viral.. this may help a lot. if we can prove on video what is happening, and get it passed around to the multitude of forums its only a matter of time before it starts popping up on anyone who is searching for ram and trailer...
just a notion.. I may do this myself.
Or we could do both
Boss, any suggestions on when i take my trailer down. What i should ask, say, etc.? All this testing is a little over my head. Im not sure how their scan tool works or what to expect.
actually what might be a better option would be to get a youtube video up... a I may do this myself.
Nice find CC. I registered and replied hoping to get an answer of what was replaced, if nothing else a phone number of the place that resolved his problem.
Hey guys check this link out. This guy had the same problem and got it fixed but it doesn't say what the issue was.
Brake Controller Not Working on RAM Pickup - Airstream Forums
