Broken exhaust manifold bolt repaired
JasonK94Z
Moore, OK
Easy job. 2.5 hours work. Bought a new Mopar manifold, bolts, and gasket off eBay for $100.
RusslRam
Was it just one side?
Sent from my Pixel using Tapatalk
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Is the heat just that excessive compared to other models?
Or is the design/weak grade of these bolts just that pathetic?
Seems like any IQ higher then 41 would make the call to upgrade these bolts after the first year of issues.
But luckily I don't think like most!
Or create thick enough exhaust manifolds that completely stops the warping issue!
I only want to figure out what exactly is the Root Cause----> Total Excessive Heat = (WHY)? Or extremely low quality parts?
Congrats on your repair!
Firebird
2019 Ram 2500
The more of these I read, the more I'm liking headers!
JasonK94Z
JasonK94Z
Moore, OK
Just the passenger side.
As much as I'd liked to have installed shorty headers, to hell with getting bolts installed in those things sometimes. The manifold is so easy to get on and off.
I used the Dorman bolt kit. Screw the Mopar bolts.
skirider
In the process of doin mine now. All apart same bolt broke.
Now im debating doin drivers side defore they break
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
I had a broken bolt same side and same place. Wasent bad at all, just glad it wasent on the bottom row of bolts.
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
They can't even figure out a .50 cent gasket for the third brake light and now we all want a permanent fix for broken exhaust manifold studs
I am not holding my breath
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
What was your tools of choice for the drill bits and bolt extractors
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Not sure about the OP but I used the Irwin Hanson 35 piece extractor kit and I little 12v drill. But, in you have a broken bolt on the bottom row you Will need a 90 degree drill. It's Very tight.
JasonK94Z
JasonK94Z
Moore, OK
I also used Irwin Hanson. The 10 piece kit works great. Got it off eBay. Part # 11119
Watch this video. He goes through it step by step. Yes, it's as easy as it looks, just takes around 2.5-3 hrs.
https://youtu.be/dQmulp2SLwo
skirider
My buddy who helped me with mine is a GM mechanic and said them and ford are both having the issue.
Not just a mopar issue.
Orca
