Justin33
- May 16, 2015
- 490
- 116
- 2015
- Hemi 5.7
So I just had an oil change and dealer must do something different now. He did a walk around while it was on lift and he showed that passenger back stud was broken. I’ve swings texted him and he’s saying they don’t mill down the manifold just new bolts? It’s clearly going to do it again here are the texts. I’m also annoyed as I have told them I’m hearing a noise last two oil changes and it was ticking from manifold. They said they heard nothing so now I’m screwed because I’m out of warranty.
We replace all the studs, bolts, hardware and gasket on the manifold that is leaking. That usually runs $350.00 to $500.00 per side.
We typically do not replace the manifold itself, just the gaskets and hardware. This generation of hemi typically has issues with studs a couple of time in the trucks lifetime due to the design of the system.
