SwollenMonkey16
Hey guys I started installing clearance lights on my 2017 ram but come to find out I do not have the white and green wire on the passenger A pillar its just the antenna wire. Where else can I tap into?
How hard is it to drill the roof. I'm assuming you had to take the liner out.All finished. Took about 4 hours making sure I did it nice and right. Thanks for the help brothers
It's thin steel, a good bit will cut right through it.How hard is it to drill the roof. I'm assuming you had to take the liner out.
Sent from my XT1080 using Tapatalk
Do they give you a template to line the lights up? I want clearance lights but scared I won't drill the holes right.It's thin steel, a good bit will cut right through it.
Who are you getting them from?Do they give you a template to line the lights up? I want clearance lights but scared I won't drill the holes right.
I would definitely go with the Mopar brand. I'm hoping there plug and play.Who are you getting them from?
Mopar and Recon I know come with templatesI would definitely go with the Mopar brand. I'm hoping there plug and play.
I was just looking at that kit. It looks like it comes with all the wiring.I got my mopar kit on eBay for $87
