Cabin Air Filter Mod
bullitt5244
2019 Laramie
Did mine this weekend!! ordered filter for 2010 Caliber and already had the cover. Thank you!
sriley531
Ohio
Did my 2014 a few minutes ago. Pretty straightforward. I do recommend heating the blade (I used a utility knife), it made cutting easier. Also pulling the upper glove box is a great tip. I was able to sit in the seat and easily see what I was doing. Only took removal of one bolt and then it pops straight out, took less than a minute and was well worth it.
ETA: I played with my HVAC a bit and there may be a slight reduction in airflow, but nothing near enough to make the system ineffective. That was my main concern, putting a restriction in would cause issues (even though most cars have these filters anyway). But alas, no problems, it's a good mod. [emoji106]
quietpeen
2021 TRX
Hellcat
I knew it wouldn't be there, but I was hoping for some reason my 2016 would already be cut and have the door but it didn't :flipthebird:
So I will have to order the door and filter and wait for the next nice weekend to do this.
R.L.K.
Bristol , Tn.
I purchased mine from a vendor here www.allmoparparts.com
Hope this helps !
I thought I read the 16s had the cabin air filter already ...
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Hope this helps !
From what I have read some 16s did some didn't !
As for the Cabin AF helping wait till you change the filter the first time :O When I did the 1st AF change in my Chevy HHR I was shocked to see all the crap it caught ! I put the Cabin AF in my 15 a few months ago and will pull it this summer just to see what it trapped.. FYI if you have a cable tied to you glove box it is spring wound and can be a bear to get back out.. Just tie a string to it and then tie it off to the door hinge or what u find easy to grab.. then when you reinstall the glove box the cable is right there
quietpeen
2021 TRX
Hellcat
I found mine has the cable. Didn't realize it retracted till I went to put the glove box back on lol. Was a little bit of a pain to get back on but I got it.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
The reason I knew about the cable retracting was because of this sight :) Saved me from cussing at it lol
Great post, OP. Wish I would have known about this earlier. :happy107:
Coenen93
Devils Lake, ND
2015 Dart
2.0L
New filter number
Hey guys I'm the parts manager at a dealership and figured I would give you the part number for the new filters for the 16s and 17s i would think they should fit just fine as the housing and the door stayed the same. P/N is 68318365AA. List price is $12.10 compared to the Journey or avenger one which is $32. If you guys have any other questions on parts just ask me and i can try to help out.
EDIT: I will have some of the new filters in on Friday and will confirm if they are the same size as the old number.
Ian
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Ian
FIRST WELCOME to the group And GREAT info on the Cabin AF :) Someone knowing the parts will be a GREAT help to us Thank You :favorites13:
Coenen93
Devils Lake, ND
2015 Dart
2.0L
New Filter
I just checked the filter and it is a direct fit for the older pickups. On that note it does have less filter material then the Avenger/Journey one. This is probably why it is $20 cheaper.
badtothebone
2017 Ram 1500 Sport
2017 1500 also need this mod, or does it come with it already?
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
From what I have read RAM started to install the Cabin AF in some 2016 and is now standard in the 2017 , Should be same AF as the mod
Oh yea WELCOME to the group and congrats on your new truck.. The crew is great here and will do the best they can to help
quietpeen
2021 TRX
Hellcat
Not that pictures are any different but I finally got this done today
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
It is amazing how much crap it will catch,, When I changed my first one years ago in my Tracker it was Nasty, Did the ones in my sons HHR and MY HHR NASTY so since then I have n=been sold on the CAF,, It will save the Evap coil as well.. Thanks to this forum I now have one in my 2015 RAM :)
badtothebone
2017 Ram 1500 Sport
Thank you!
Enjoying all the reads, lots to catch up.
quietpeen
2021 TRX
Hellcat
I guess my.2016 was made too early lol
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
So was my 2015 lol from what the Gals/guys have said it was hit or miss on the 16s, I assume the later built ones were more prone to get 1
Broyd
Rossland BC Canada
No 2016's came with a filter installed. Late builds (May) did have the factory punched out hole and a door installed. I read that the factory started using 2017 parts.
