Cam plus other stuff?
Davy120
Davy120
fairchild afb
That's what it sounds like, how's the crazy jay compare to the 6.1 cam?
Camo Ram
truckin151
2013 sport
Reason for mentioning pulley was more for helping with the higher than stock reving. After i sold mine to Greg I put a new OEM givin the age of the truck as the rubber around the pulley dries out over time. Was not aware of the characteristics of a UD pulley as you explained, but i beleive you and will think about that the next time i hammer the Magnum as shes got a powerbond 25 UD to spin the Crazy Spartan!
I am almost positive that although it adds hp, it adds it up top because you can reach your peak power band faster. Good for cars and high revving cams.
Davy120
Davy120
fairchild afb
Also would a tb benefit me at all? Like an 85 or an 87?
Camo Ram
truckin151
2013 sport
throttle body will help, make the throttle more responsive. Doesn't add any hp, but makes for a fun ride.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Lots to read about the Crazy Jay which was comparable to the awesome sidewinder by FRI. Google it for a while. I think it would be a good cam to run on the SC and has a good bal of torque especially down low even better than the Crazy Spartan for an 03. I think on a 114 lsa it would be good but Stu at Inertia would be able to confirm whats best. Well worth the Money and will get ya going sideways!
Davy120
Davy120
fairchild afb
Sweet we have a starting point now :) thanks guys.
And should I still get all the 6.1 stuff? And the water pump.
Camo Ram
truckin151
2013 sport
6.1 springs and push rods are needed for a cam swap.
ST-8
Some cams don't need em but for having an 03 its a nice safety blanket.
03/ early 04 were known for having bad springs.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Mario your 04 is a great year for a 260 install! I like your mods list. Davey you can get 8 exhaust rods that are custom length for the Crazy Jay for 70 bucks then 6.1 on the intake side which are bang on. 6.1 springs are for running up into the 6k range and given the age of the truck like Greg said you do the seals. So the list grows. Some gaskets although reusable may be required (timing cover, water pump if having a look to check corrosion of water pump to cover, valve covers) including crank seal but if its not leakng your good.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
To answer the waterpump question, it depends, on Cam #2 swap i replaced mine as i found the gasket channels on the timing cover to pump corroded by the Antifreeze over time, cleaned the aluminum casting and bought a new water pump which I beleive has the new rubber channel gasket included. I replaced it given the age of the truck and it comes with a shiney new pulley already press fit to it. I also replaced the tensioner and small black standalone idler pulley. I also painted the cover Hemi orange which is the same scheme as my valve covers.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I would change the springs on any cam because of the strain that the higher lift puts on the springs. The 6.1 springs are cheap insurance IMHO.
ST-8
Thanks Danny:) only thing I should of done during the cam swap was clean my valve covers. They look awful!
truckin151
2013 sport
or just pull the heads, that's what we did. didn't take much longer and gives some more elbow room while working.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
First cam we did we pulled the heads also and used a reguale c style valve spring tool. The head bolts and gaskets for the heads were fairly cheap.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I certainly wouldn't unless you are doing work on the heads. But you will need the tools to pull the valve springs with the heads on if you don't. I think that made sense....
Davy120
Davy120
fairchild afb
Ok so remove the heads, ill need new studs and gaskets.
Don't remoce the heads ill need a special tool to remove the springs?
Hmm the choices hahaha
Camo Ram
Redtruck-VA
Virginia
Camo Ram
And consider rhe need to remove the exhaust headers and new gaskets for them when removing heads. Also think about if this is a good time to either replace the heads or simply mill them. It never teally ends....
Davy120
Davy120
fairchild afb
I just put them on as well as brand new mopar gaskets lol they've been on literally like 10 days
Camo Ram
