Cammed 4th gens
greychevy
Orlando, FL
Who out there has cammed their 4th gen? In my research I can't find a 4th gen that really benefited from an aftermarket cam. Yes, there have been a dyno sheet or two but real world results (I.E. track times) I'm not seeing :flipthebird:
charonblk07
Calgary, Ab
F1-A forged 349ci
Some decent results on the LX side of things when it comes to track times, but haven't heard from anyone on the truck side. The biggest trouble is to run a large cam that will make a difference you need to lock the cam phaser, or install new pistons with a bigger valve relief.
ericlee9386
I picked up about .3 tenths with the 6.4 cam running on my 24's. Went from 14.99 down to 14.75
ericlee9386
It was done by hemifever. Their are parts of the tune that still needs work.
ericlee9386
Nice man! What else needs to be done in the tune?
It's running really rich while at WOT and when the truck is cold it will stall when braking or turning unless you drive slow for a few miles. I believe it's called the ramp down speed is what needs adjusting.
ericlee9386
Sean think he'll be able to tune it out?
Nope. He is already at the max of his tuning parameters for this. I am going to have to switch to mike at ost. He says he can cure all my issues
Jerseymike
That is the same problem that was in the other 35 page thread. I think I read they were able to tune it out eventually. But that was Arrington with many, many, many... hours of tuning on that truck.
ericlee9386
I agree this has not been as easy as it was advertised in the beginning but with you being near After hours performance they are a lot better in the tuning process and you may have a better experience.
ericlee9386
I don't see why you are having tuning issues with the 6.4 cam. I ran it just fine on the stock tune....
2011 Ram 6.4 Cam Idle and Rev: 2011 Ram 6.4 Cam Idle and Rev - YouTube
2011 Ram 6.4 Cam swap:
2011 Ram 6.4 Cam swap - YouTube
Yea I know. I modeled my install after yours. For a while it ran fine on a canned tune with no surging or anything. Then one day it just started to act crazy after I tried to get the surging tuned out of the custom tunes. It does great after its warmed up and the issues are none existent when you drive like a normal person. I just personally know it's not 100% and that's what I am looking for
greychevy
greychevy
Orlando, FL
Well it's it's running real rich I would say it isn't anywhere near 100%
fasthemiram12
Eagle 5.7 vvt
Did you use the Auto W/ MDS cam or the manual trans cam?
ericlee9386
Auto they only difference is I did the comp push rods
ericlee9386
I want to say they were stock replacements but I would have to look it up
