Carli track bar jam nut help
zeddy
Burbank, Ca
Hey guys, the jam nut on my track bar keeps coming loose. I've tighten to the point my arms shake and lost a few mm of skin off my knuckles. I've put red lock tight and it keeps coming loose. I want put another jam nut against the jam nut.
Anyone know what size the nut is and can I get it from lowes or homedepot????
Post a pic of your track bar. You're doing something wrong if it's the Spohn bar you're dealing with,you shouldn't need to double nut a jam nut,especially if you've used red Loctite on it. Even if one side of the adjuster loosens,it still shouldn't turn as it's a solid mounting point on both sides of the bar,and techinically one jam nut should keep the adjuster from loosening. You are tightening the jam nuts against the steel bar on both sides I hope.
JustinRam1500
