Catch Can, Breather HELP
JPOW
Hey guys,
I have a 2004 5.7L. Ive had a CAI on the truck basically since new. I have a filter on what i believe is the Crankcase breather. However, i am getting a lot of blow by. Oil is getting everywhere. Every so often i have to replace the filter because it is clogged with oil. My question is, What do i need to get to replace this? I've done some research and have narrowed it down to either just a Moroso breather catch can, and a BT Catch can. Im just not sure.
I Believe that i just need something to catch the oil and breath, without having to reroute back to the PCV Valve. Am i correct? Thanks, JPOW
07rambo
I installed a 15$ catch can from eBay and it works great haven't had any oil on filter since and it has a lil clear tube to see how full it is
GoldDot
May be time to check your pcv system for proper operation, leaks and anything unusual. Have you ever replaced your pcv valve?
Properly operating pcv system should stop blow by through the make up air line.
R.L.K.
Bristol , Tn.
A good read on PCV system @ www.oilcatchcan.com
If my posted link doest work just go to oil catch can.com
