Catch cans
Rlaf75
East Hartford CT
I've been scouring the forum and it seems that alot of members use catch cans. I did some research and it seems to make sense. The less contaminants being pushed back through the engine the better and it's really a simple design/upgrade. Basically an ounce of prevention is an ocean of cure sorta thing. So with that said, what is everyone using for there catch can set up? Did you purchase one or did you make one. Pics and links are always welcome. Thanks
MADDOG
Out Exploring Arizona
I use a Billet Technology can on my SRT and am currently investigating what is available for my new 6.4L powered Ram.
Moe's Performance has them so check out their website linked at the Vendor section. They are getting ready for a Black Friday sale and may have a coupon available on these.
Moroso makes quite a few catch can styles and I believe Jegs has them in their catalog as well.
Here's a pic of the BT unit I use on my SRT.
charonblk07
Calgary, Ab
F1-A forged 349ci
I run a dual catch can system on my engine with an independent vacuum source. One can is a Billet Tech (green) and the other is a UPR can (silver); there is a very definite difference in quality of fit and finish between the two with the BT one being much better quality. The UPR one is taller and narrower but holds the same capacity as the BT one and the UPR does have a 1/8"npt hole on the bottom if you wanted to add a drain which the BT doesn't have.
R.L.K.
Bristol , Tn.
I used the Elite Engineering Oil Catch Can, very nice finish and available in several colors .
The internal passage head design I believe is better than some others that's why I went with Elite Engineering.
www.eliteengineeringusa.com
Also a good read here on oil catch cans
www.oilcatchcan.com
At my most recent oil change @5k miles this is 8.5 OZ of oil that did not make it into my intake !
Hope this helps !
xrsman
Ontario
3.0 Ecodiesel
I run a bullet as well! I check it randomly and dump it.
Sent from my SM-G920W8 using Tapatalk
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
I run the Billet Technology cans on all of my hemi vehicles as well. We have these marked down to only $119.99 shipped through Monday. Check out the link below...
http://www.moes-performance.com/Billet_Technology_Catch_Can_09_15_Dodge_Ram_Hemi_p/20014.htm
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Can you provide braided lines and connecters for it to work with the setup or?
Yes we can, but we only stock them in the satin finish with regular PCV hoses because BT has a 20 business day lead time on any cans in color or with braided lines.
BlownGP
Houston/Baton Rouge
What did you use to keep it at $30. I've looked online and everything I've seen is over $100 for these?
It's one I had laying around for my grand prix. I used it has a coolant reservoir.
So it's just a universal one you can get on ebay. Bent the supplied bracket 90* and bolted right next to the fan shroud. Got some fuel line hose, used some hose clamps I had. DONE.
I like the BT ones. It's PRETTY but rather spend on the money on something else since I had this one already.
thoffmann517
