Change transmission fluid?????
Upmichigan
Upper Michigan
I have a 2014 Ram hemi quad cab 106000 miles. Northern Michigan. No hard service. Should the fluid be changed if there are no issues???
Thx in advance
I would, but if it is the 8 speed it isnt an easy task and very expensive at the dealer.
Daw14
Yes , axles and transfer case also would not hurt.
Jeepwalker
WI
2012 Reg Cab, 4x4
Don't forget the brake fluid (exchange) and engine coolant (used distilled - not tap - water with the new coolant).
The most over looked fluid but the most important if you like the ability to stop.
