charonblk07
- Mar 14, 2013
- 4,056
- 2,072
- Location
- Calgary, Ab
- 2009
- F1-A forged 349ci
I'll say this;
In my opinion the majority of people's belt slippage issues are caused by insufficient belt wrap and/or tension, not the type of belt or the number of ribs.
I was running 17 lbs boost making 600rwhp on my mustang on a six rib belt. I had a 10% OD crank pulley and a 2.65" supercharger pulley, and ZERO belt slip. I also had a ridiculous amount of belt tension and belt wrap.
Most definitely belt wrap is a big issue with my setup, the downside of the Ram's Procharger bracket is you can't get another idler pulley closer to the blower because of the way the blower's clocked. The bracket is also flexing a lot because it's so long and the entire head unit is unsupported. The tensioner is maxed out and with how tight it is there's about 1/2" between the upper belt and the one running over the tensioner so that's stopping another idler being installed or reclocking the tensioner.
As you can see, the bracket is massive and those 4 bolts at the bottom are the only connection to the engine, the rest is free to flex and it's bad enough that I can actually flex about 1/4" either way by hand. My bracket will be a lot closer to the block and will be braced back to the head as well as have multiple bracing plates to stop any flexing.
