Climate Control problem
Mary Row
Lakeside, Ca
My A/c and heater in my 2011 Dodge Ram 3500 both stopped working. The blower seems to be working but air only comes out on the floor and it’s neither hot or cold. When testing the fuses it seems like a large number of the small fuses in the fuse box aren’t working but fuses are good when inspecting actual fuse but test light doesn’t light when testing that way. Any ideas????
renfrick1
New Fairfield
Sub’d. Mine doesn’t change from defrost to vent. Just stays on floor
M
Mary Row
Lakeside, Ca
That’s same thing mine is doing but I also have no a/c or heater.
CincyCuda68
Ohio
More than likely actuator door, very common issue. If you search google, there are aftermarket ones that have metal tabs instead of plastic and should be a permanent fix.
Ken226
Washington State
I had the same problem once on a 2010 bighorn.
Cincycuda called it right. Mine was a blend door actuator motor. Replacement was about 40$ at Oreillys.
