color interior trim
Hemimania
Central NJ
Have a 2015 and would like to know if there is a color replacement for the chrome molding in the center console and around the vents. I've looked but couldn't find any. Thanks.
Tonino
Administrator
It's called Krylon for Plastic..comes in just about any color you want. I'm sure some may even chime in with Plasti-Dip, not as many colors offered through
EagleChief
Oklahoma
2014 Big Horn
Yep. Spray paint is your friend. Painted mine Orange.
kg93
AZ
actually there are quite a lot of colors available with plasti dip now. I would only use plasti dip as a test.
The plastic spray paint is only good if you want to take the trim off completely
i would use vinyl and an x-acto knife
Treburkulosis
Your High End Detailer
Haslet, TX
I vote rustoleum. I prefer the way the tip sprays vs the fan tip.
DailyRam
North Carolina
Paint is a good option, but if you're looking for patterns (carbon fiber or wood) then carid.com has dash kits. They seem to be a pretty penny though.
deangtp
I took it out. I unwelded it scuff primer and paint. 2k clear. Welded it back in. Someone here recently ground the welds down and put little clip screws back in. Made that easy as anything.
