- Mar 30, 2014
- 6,096
- 4,175
- Location
- SC
- 2022 Ram 1500 (5th Gen)
- 5.7L
@R.L.K.
Did you see this?
M² Mods - From my non Flammable S7!
Did you see this?
Whoop! Conversion done! 2016 Rebel from a RA2 to a RA4. Only one real anomaly, the screen wonkiness..... Technical term <G>. I originally tried just the radio, all the features "seemed" to work but the buttons just seemed off and were slow, sometimes didn't even work. I did some searching for a calibration way and found the up, down, browse. Issue was I still had my RA2 bezel, that didn't have those. I ended up just temporarily patching in the new bezel, cable and hvac module. Fired it up, did the calibration and everything works great.
I did do a full radio reset from the engineering menu. Fired it back up, had some "learning" phases it went thru. One time the NAV button was gone, it had a screen off button instead. The NAV was still present on the radio and worked fine, it was the shortcut button that was missing. Turned off te truck, turned it back on and the NAV button was back.
Prior to the reset temp slider had a temperature, it appeared to increment by 2 degrees. After the reset that doesn't have the degree anymore. I'm sure it's a setting in the engineer menu, just haven't found it yet.
Outside temperature display, that went away after the reset. Found that setting in the engineering menu, that back now.
All XM subscriptions are active... hopefully they don't catch that.
Uconnect, doesn't work. My guess is because I don't have the cell antenna, using the fixer plug.
Couple other things to note.
1, All the trim on the passenger side. None of mine needed to come out as the guides indicate. Not sure if it's only needed for the 4 speed conversion, mine was already 7 speed. Z The only trim I had to take off was the side of the dash.
2, Passenger vent. No need for that to come off. I didn't need to, HVAC module went right in behind it.
3, 7mm open end is your friend! Use that for the inside screw on the HVAC module.
Thanks to Grimm for an awesome harness! Thing is a masterpiece!
I just held down where it said "Display temp = false", while holding it it changed to "Display temp = true" and the temp popped up. Now I don't know if it was a fluke and the radio was still learning, but if a fluke it was a good one since I was holding it when it changed!
