DB ALL Remote start
Darrin Sevitz
Ohio
Can someone point me in the right direction to get a remote start for my 17? I want to use my factory fob. I want a plug and play system. Thanks
CincyCuda68
Ohio
You can add remote start for practically nothing. There are two ways, first you can just buy new rubber inserts for your key fob and ground one of the taps in your electric box then program or the second way is to add the new hood latch. I did the hood latch so I think it cost me just over $100 for factory remote start.
You will need Alfaodb to program or take it to the dealer and have the sales code added (which will be another $100).
This upgrade is really quite easy.
Key fob inserts
QualityKeylessPlus TWO... https://www.amazon.com/dp/B017MVAO6Y?ref=ppx_pop_mob_ap_share
See post here
https://www.ramforum.com/threads/how-to-add-remote-start-to-2017-ram.99849/
Kapt
3L
Saw this. Little pricy though
big daddys house
Hill Valley
that's exactly what I did accept that guy's charging everybody a hundred bucks to flash their module and you can do it on your own computer for free. (If) you have mild knowledge and patience for it. I had to flash my box four times before I got it right [emoji35]
I am however really interested in that other way that was posted for just grounding out your remote or something and enabling auto start with Alfa OBD.
I like to Tinker [emoji23]
Sent from my LG-LS995 using Tapatalk
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
I did exactly what @CincyCuda68 posted. Total cost for a new hood latch and and overlays off ebay less than $45. I'm pretty sure 2017 and up comes from the correct RF hub that make it really easy.
Lawsuit11
Fort Worth, TX
You just need the hood latch. The wiring and running it. I did it on my 18 and it’s OEM remote start non of that extra modules etc. just need ALFAOBD or someone around you that can help you that has it. It’s simple and priceless in my eyes
—2018 Ram 1500—
big daddys house
Hill Valley
I wish AlfaOBD was hot when I installed mine.... [emoji17]
CincyCuda68
Ohio
All you have to do is run the wire that would go to the new hood latch to ground, that simulates the hood being closed. Everything else is the same.
big daddys house
Hill Valley
What the SH*T biscuit! And then just enable it in AlfaOBD that's all I had to do?
big daddys house
Hill Valley
And change the rubbers in your fob lol. That’s it. Should cost you less than $20
I already installed autostart years ago with flashlogic. But i might just try this for fun.
To your recollection does this method work for a 2014?
Lawsuit11
Fort Worth, TX
With a 2014 you need a new RF hub/antenna attachment because 13-16 do not have built in antennas in the RF Hub like 17-18 RF hubs do.
Someone correct me if I’m wrong.
—2018 Ram 1500—
CincyCuda68
Ohio
—2018 Ram 1500—
Exactly! The OP has a 17 so @big daddys house you are SOL, sorry!
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
I'm about to pick up my new 2019 Warlock based off "classic" Would any of this apply since it's the same basic truck as the 2018? Seem not too many online places distinguish between classic vs all-new versions?
CincyCuda68
Ohio
It should be exactly the same as the 2018. You should be good to go!
JScroggs
Fredericksburg, VA
5.7-liter Hemi V8
So am I reading this correctly that all I need is the FlashLogic and some programming done by a local shop or dealer and I can use my factory fob?
big daddys house
Hill Valley
What year is your truck?
