UPDATE! SITUATION RESOLVED!!!!
I did finally receive an e-mail back from Chrysler Customer Care on Monday 11/12/18 with the following response:
Kris,
Thank you for contacting FCA US LLC.
VIN: 3C6UR5CJ6HG5*****
2017 Ram 2500 4x4 trucks with the double cardan front driveshaft have a grease fitting (factory equipped front driveshaft), which requires maintenance at every oil change.
A quick Google Image internet search has several examples of photos, some with arrows pointing at the grease fitting.
The double cardan universal joint on the front propeller shaft near the transfer case is equipped with a flush mounted grease fitting. The grease fitting is a concave tapered hole on the shaft and can be difficult to locate. The grease fitting may be hard to spot right away and may require some searching before locating the grease fitting. The grease fitting is normally covered with dirt and can’t be seen unless cleaned really good. This fitting requires a needle nozzle for applying grease (the tip should be coned shaped >). We suggest that you have your local dealership first verify your vehicle is equipped with a double cardan universal joint front propeller shaft. Once this is confirmed and if your local dealership is unable to locate the fitting, our suggestion would be to seek a second opinion from another Ram dealership that has a technician more familiar with this model vehicle and whom has performed this type of maintenance on a like model vehicle.
Sincerely,
Joe
By the time I received this e-mail I had already received a similar response after private messaging
@ramcares through this forum. I then contacted the service manager at my local dealership via e-mail and provided him with a copy of the private message I had received stating the lubrication instructions were not an error. He scheduled for me to come in this morning, and sure enough when he put it up on the lift, there was the grease fitting. He had a tech come and in about 10 seconds had it lubricated. I did ask him to provide me with a service receipt showing the front driveshaft had been lubricated, and he obliged. I wanted to have the documentation since I previously had them document on my service tickets when they stated that the truck did not have a grease fitting. This way if there is ever a problem I can show that I requested the work performed, and it wasn't until the truck had 34,000 miles that they actually performed the service.
Overall, the whole process was a headache, but at least from this point forward I know that my dealership is aware of the proper lubrication to be performed on my truck. Also, I expect this will prevent a whole bunch of other people from receiving misinformation from the dealer as well.
Hopefully anyone else who has a similar situation will be able to locate this thread in the future and it will help them out.
Thanks again everyone for your comments and feedback!
