avolnek
- Jan 5, 2015
- 266
- 96
- 2015 Ram 2500 CCLB
- 6.7
85,000 miles, over 55k towing has only solidified my choice in buying a gasser. Flawless ....
Comments like this are just moronic.
I understand the need/want for a gas engine, i've been there and done that. But to state that you're towing 15,000 pounds and up with a 6.4 hemi and by your numbers doing so more often than not and act like you're better off in a gasser... you've flat out lost your mind or you're bending the truth somewhere...
lets break this down...
85,000 miles on a 2014. so let's say youve had it for 2 full years now. that would be 42,500 miles a year, not unrealistic but up there...
Now the common perks to a diesel engine over a gasser are the long run fuel economy, better fuel economy while towing and reliability. The latter is very arguable so we can kind of ignore that for now.
my 2015 6.4 hemi's best fuel economy was 14 mpg.
My 2015 6.7 ******'s best fuel economy was 21 mpg.
towing my 5th wheel my 6.4 hemi got 5-6 mpg
towing my 5th wheel my 6.7 cummins gets 9-11 mpg
so for the "reasons" you bought your hemi i disagree with you... Your situation with higher miles is the prime example of why diesels are around...
if your hemi suits you that is great and dandy but there are much better ways...
I drive less than 2 miles to work each day with my cummins, on winter blend fuel, a fair amount of idle time and in sub freezing temps with that short of a trip i still net higher mpg's than my hemi did with the same trips in the summer time.
To each their own, but i'm very fond of using the right tool for the right job...
