Dirt in-between sheet metal over back wheel on bed
bozeblake
So I noticed the paint was bubbling over my back tire do started scrapping. Well it is a rust trough on my truck the only one. Well there was about and inch of wet dirt behind the rust. Has any one had this happen and how does dirt get in there? Did not see any openings.
Sent from my XT1585 using Tapatalk
crazzywolfie
under the truck
the dirt can get up there from the front or back of the box at the bottom. the area behind the quarter panel is not sealed from dirt being toss up there.
bozeblake
bozeblake
What is the best fix for this? I would like to fix this before I welded in new metal. And the metal rusted out right where the dirt was.
crazzywolfie
under the truck
i don't know. you could possibly weld in some more metal to limit how much dirt could get back there.
bozeblake
bozeblake
This truck has a bed liner. should I take it out? Will they make bed rust
crazzywolfie
under the truck
if it is one of those plastic one they can sometime cause a bed to rust if water gets trapped between it and the bed and get to sit there long enough
bozeblake
bozeblake
Thanks for your help. It is a new project, Man these Rams are tough my first one every thing hold up so good on these things, I got that rust but that is it on rust.
Orca
