ozturkebrahem
- Joined
- Nov 15, 2015
- Posts
- 8
- Reaction score
- 0
- Ram Year
- 200e
- Engine
- 4.7
I have 2003 dodge ram 4.7 stick shift k&n drop airfilter gbison headers magnaflow high flow cats Gibson dual exhast cat back I change the fanclutch to electric fans 2 14 inch with flex lite termostat new coils new sparkplugs champion iridium new water pump new alternator new radiator calipers rotors new tps and and idle control valve clean throttle body always using 93 octane and full synthetic with lucasfull synthetic add at every oilchange car runs like a dream I have 1 problem I can't figure it out one is after starting the car car runs like ticking time bomb till 1 minuet then runs very smooth until I try to acclerate under load it try to stall out after review the engine to 3000rpm everything works fine without any problem then after I stop the engine for like 15 minuets start it back up does the same thing after reving to 3000 rpm then everything works like a dream again car has 167k inside the engine is super clean I'm thinking something wrong with the electrics anyone find a solution for this problem???
