drilled and slotted rotors?
Davy120
fairchild afb
are they worth the extra money? and do they need to be put on a lathe every so often like the regular ones? also are the green stuff pads good to go with it or are the regular cheapo pads good enough?
thanks in advance only asking cause im in need of rotors bad
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
You only need to do the front because they do about 70-80% of braking anyway. I have done these in the past and really liked them I felt the drilled only were a little better than drilled and slotted combined maybe that was just my experience. Helps a ton with premature warping that tends to happen in the front. They can however crack easier which I have never had happend but do invite more chance in that area.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Paired up with a quality set of brake pads, slotted rotors are a nice improvement over stock. I prefer the slotted myself over drilled and slotted.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Never tried just slotted personally. I always pair with ceramic brakes because I hate the black dust all over from semi metallic pads.
$miley
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Yep. Ceramic pads are definately the way to go.
Davy120
Davy120
fairchild afb
hey will how are those pads that come with those?
so are you guys saying i should just get a new set of oem rear ones then? and can you get ceramic pads from autozone or napa or something?
Catchin Zs
Wilmington, NC
They're pretty good man, I love them. I want to get the rear kit too. No noises and brake dust really doesn't show, when it's clean... which isn't very often this time of year :D
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Well you probably dont even need new rear rotors I usually dont have to replace them or even turn them in the rear until I have went through at least 2 or 3 sets in front. I would only do new pads in the back and all new up front. I can usually go 80,000 before first brake job and even then only need to do the front.
Davy120
Davy120
fairchild afb
yea i wouldnt be too worried about except the rear ones have a nice little lip all the way around them i just wanted to start off fresh.
blackout11
alpharetts GA
2011 R/T
ya they are great but just remember if you let your brakes go they cant be turned you have to replace them
Davy120
Davy120
fairchild afb
hmm thats a good point hmm so basically just keep updating my pads and dont let em wear down to much and i should be good?
