Driver side door power lock will not work
kdikert
Espoo, Finland
Hi,
The automatic locks will not work on my driver side doors. The passenger side doors work well, both from the key fob and the door lock button. The problem was intermittent at first, so that the issue happened only when it was rainy. I lived in sunny California at that time, so it happened only two times there, but then I moved up north and the issues became more prominent. There was clear connection with humidity and doors not working. Now after one rainy winter the driver side doors will never work, so now the problem is consistent.
The door ajar detection works fine. The dash shows door ajar correctly if I open or close each door, even those doors which the power lock won't work on.
This seems like there could be a worn and shorting cable in one of the doors. Any ideas on how I could start troubleshooting this? Is there any particular splice or connector I could start working from?
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
First WELCOME to the group
I would take out the door switch and check connections for corrosion !
Not sure about the RAM Door Switch but some you can take apart and clean the contact pad!
You Tube should have videos on it !
Dorman makes a Master Switch as well as on E Bay !
Dorman around 100$ and E Bay average 30$
Ill see if I can dig up anything
Also try the search box on sight !
I just tried the search box and there are many threads about the switch ! I typed in Drivers Side window switch
And https://video.search.yahoo.com/search/video;_ylt=AwrFNzzFAVlk8RgASDH7w8QF;_ylu=c2VjA3NlYXJjaAR2dGlkAw--;_ylc=X1MDOTY3ODEzMDcEX3IDMgRmcgN5ZnAtdARmcjIDcDpzLHY6dixtOnNiLHJnbjp0b3AEZ3ByaWQDVlJxUmY1ZnJTd2l2X1luaERnSlpEQQRuX3JzbHQDMARuX3N1Z2cDMARvcmlnaW4DdmlkZW8uc2VhcmNoLnlhaG9vLmNvbQRwb3MDMARwcXN0cgMEcHFzdHJsAzAEcXN0cmwDNDAEcXVlcnkDMjAwOCUyMFJBTSUyMDE1MDAlMjBkcml2ZXJzJTIwc2lkZSUyMFdpbmRvdyUyMHN3aXRjaAR0X3N0bXADMTY4MzU1NDc3Ng--?p=2008+RAM+1500+drivers+side+Window+switch&ei=UTF-8&fr2=p:s,v:v,m:sb,rgn:top&fr=yfp-t
kdikert
kdikert
Espoo, Finland
Thanks for the tips Rado!
I took the driver's door switch panel apart, but all the connections seem good. I'm getting a feeling that the problem might not be in the doors after all.
I got a copy of the Factory Service Manual. Firstly I checked the wiring to the locks, and that indeed shows that the driver side front and back doors share one of the actuation wires. I measured the voltage in the door lock actuation wire, and it seemed to jump between 6-20 Volts when opening the doors.
Having found out very little from studying the wirings, I checked the door lock diagnostics in the FSM. It seems to have a handful of troubleshooting sequences for the driver side doors. The doors seem to be ultimately commanded by the gauge cluster (obviously...). Now I'm recalling that I replaced one of the gauge backlights, and the door problem may have started at the same time. The remedy recommended in the FSM for many of the door problems is to replace the gauge cluster . I think I'll still go over the troubleshooting sequences carefully....
The FSM says that the onboard computer may store trouble codes for some of the door problems. Would anyone have recommendations for an OBD2 tool to read such particular manufacturer specific codes?
tron67j
Maryland
Not sure exactly understand the problem, but is it that you can put the windows up and down from the individual switches on the other doors and also open and close the locks but you can't do say the passenger window from the driver control? If that's your issue, it's a pretty common one for gen 3 trucks. Just get a new door switch control unit. What it is is one of the solder joints degrades and it causes the connection to not work. You can fix it, but honestly the part isn't that expensive. Reach out to Benny at all Mopar parts in the vendor section and he can set you up with one.
Daw14
check the wires where they go from cab to door, their have been lots on here that have broken or exposed wires in those harnesses.
