Dually Conversion
wamfire20
Magnum 5.2
Thinking about turning my 1997 1500 into a dually. It has a 5" lift on it. What all would I need to do this? Would I need a new lift? Any answers would be helpful
codered
in da ghetto, FL
1998 QCSB
magnum 5.9/360
it's not suggested since the frame for a 1500 isn't strong enough for 25/3500 stuff. But, you can pull a dually rear axle from a 94-01. if you pull everything from the donor dually, it's just best to buy a dually and work on it.
W
wamfire20
Magnum 5.2
Oh yeah that's true. It probably would be a lot easier and cheaper to get a donor. Thank you
Johnn123
Ontario
You can swap 2500/3500 stuff over fine. A few people have done it, Merc225hp on here has done it no problems. Legally it will still be a 1500 however.
All you need is the rear axle and dually box, possibly leaf springs and hangars depending how you wish to mount. You could use your half ton springs and weld a new perch on the axle, however if I were you I would swap leaf spring perches over to your frame and use the 3500 leaves.
codered
in da ghetto, FL
1998 QCSB
magnum 5.9/360
i knew that but if he wants to go into 3500 terriotry with towing and what not. it would be best to build the donor truck.
sent from my brick using clay
Johnn123
Ontario
Oh ya absolutely, you're right on there!
Merc225hp
NA
truck
gas
Thay are?
W
wamfire20
Magnum 5.2
Thanks everyone for the help. No I don't want or expect it to perform like a 3500 for towing or hauling. I'd like to keep the lift in the back, what option for the leaf springs would be easier to keep the lift?
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
Dont just think about the rear diff, you'd have to change out stuff in the front as well unless you want 5 lug in front and 8 in rear.
Johnn123
Ontario
To keep the lift you could swap leaf spring perches from the stock 3" on the Dana 80 to 2.5" wide perches. However I'm not sure I would do that with a dually axle, anyone else care to comment on that? If I were you I would just look at getting a 3" add-a-leaf for both sides and adding those to the 3500 leaf pack to get your lift back.
A great point I meant to add and forgot to, yes if you're doing the rear you'll want to the front. You'll have different lug patterns if you don't. The front swap benefits far out weigh then rear swap benefits. The Dana 60 front is far superior to the Dana 44 you have now, it is far stronger, better steering and direct bolt in. Yes you can use all your lift parts with this axle as well.
