eBay LED Map Lights = Service Shifter + Rear Parking Sensors message
Giorgio_Rampa
Vaudreuil
V6 3.6L
More of an FYI incase someone runs into this problem...
I changed the 2 map lights to LED, as soon as I changed them to LED, I got these two messages:
Service Shifter
Rear Parking Sensors deactivated (if you press the button to turn it on, nothing happens)
Switched back to the OEM peanut bulb (non-LED), both errors went away.
So much for putting LED bulbs there!
Edit:
Also the compass stopped working
hunterdan
SE PA
2019 classic
Service Shifter
I've had LEDs in mine for several months with zero issues.
I lied, every now and then the interior lights just wouldn't come on until the truck started. I've since swapped the led bulbs to canbus bulbs and haven't had issues.
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
I noticed my compass stopped working as well.
These were non-canbus LED, that's probably the issue.
indept
South Jersey
I have non canbus LEDs in all my interior lights for over 5 years and no problem
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
Got the compass back by doing a complete factory reset via the radio (Lost all the saved settings, presets and Bluetooth paired devices)
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
Finally upgraded all the interior lights to LED, missing one was the rear dome light:
turkeybird56
Central Texas
Put these in MY 2019 5th Gen. They were also in my 2015 ED. No issues: Map lights and big dome light in rear and footwell.
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
The 4th gen uses a 44mm dome light bulb, I ended up putting these in the interior. They work perfectly.
