Hello Guys,
I sold my 2500 cummins which was getting 15mpg combined, it was a beautiful truck but O2 sensor problems made me sell it, 38 days in the shop the first year of ownership. I could have fixed the truck my self by doing deletes by did not wish to take a chance voiding my warranty on a problem truck since day one.
In 11/15/13 I purchased A 14 jeep grand cherokee limited 4x4 3.0 eco diesel.Now at 4500 miles I am getting 27 mpg combined on my last tank full of fuel.
ON EDIT: MY Jeep Has the trailer tow package with automatic load leveling rear shocks and sway control, it is rated to pull 7400lbs! I do not think I would want that much weight behind this Jeep. But I will try and pull right at 6000lbs sooner or later this year moving one of my milling machines,of course I have WD hitch with sway control built in it
Supposedly the 5gallon of DEF Fluid is suppose to match needing filled at the same time as oil changes are due which is every 7500 -10,000 miles depending on what the oil life sensor tells you.The torque of the diesel is toxic (FUN) and still get 27 mpg when having some fun at stop lights.
Def fluid can be bought at walmart,auto parts,truck stops for $13.00 per 2 1/2 gallon jug.
MY motor is quite it does not sound at all like a typical diesel,in fact most people probably do not realize its a diesel!!
I pulled my 5x8 trailer 650 miles with 600lb on it running 65-75 up the interstate and got 26mpg. Return empty mpg went to 28 mpg and down hill from NY to SC. HAHA
I got to play some in the snow in NY they had 42" over night while I was there. The Jeep with stock Michelin Latitude tires had no problems coming up out of my friends shop driveway. Driving a Diesel in the snow takes some getting use to because you must drive it differently because of all the torque. The best way I found was to select the correct gear and just let the diesel pull it self with out much throttle input.
The best mpg I have seen so far was a trip up the interstate running 70-75 and got 32 mpg with the cruise set,my jeep is 4x4 with off road II package meaning it is awd/quadatrack.
The 3.0 eco motor has been in europe and australia for almost 4 years with good proven track record.
Of course they do not have all the EPA BS on their vehicle so they are getting much better mpg.
So far my jeep has been to the shop 1 time, free oil/filter change,uconnect update,and a PCM update were all done at this one trip.
If I have no problems this first year I will have no worries or problems thinking seriously about deletes to let the motor have longevity and run the way it was designed with out EPA BS.
Since I live in a state with no inspection or smog inspection.
MY neighbor had basically the same jeep as I have but the had the 3.6 pentastar and was getting about 22-24mpg combined.
So my ECO Diesel does 3-4 mpg better than their 3.6.
