Emergency fuel cutoff switch?
Discussion in 'Engine & Performance' started by kdryan, Jan 2, 2017.
Sponsored By: Moe's Performance
  1. kdryan
    kdryan Member
    76
    Oct 11, 2015
    Ram Year:
    1998
    Engine:
    5.2
    So my '98 Ram 5.2 stopped running in the middle of the road on Christmas eve. It's getting spark, but not fuel. I sprayed some starter fluid into the intake and it started, so it's not getting fuel. I replaced the relay and the fuse looks okay, so I am thinking fuel pump. If it is, it's going to sit until spring because I am NOT going out there in 30° weather to drop that tank! Before I set it aside for the winter though I wondered i there was an emergency fuel cutoff switch somewhere. I know I ran into that on my Mustang and an old Grand Marquis I used to have so I thought it might have one...
    Any thoughts or advice on doing this job?
  2. sbarron
    sbarron Senior Member
    2,727
    1,538
    Feb 28, 2015
    Wasilla, Alaska
    Ram Year:
    Engine:
    when you turn the key to "on", can you hear the fuel pump come on momentarily?
  3. dudeman2009
    dudeman2009 Senior Member
    22
    1,395
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    Fuel cutoff is controlled by the PCM through the ASD relay. I believe the ASD relay also cuts off power to the ignition coil. If you want to check and the problem still persists, in the underhood fuse block, swap the A/C compressor clutch relay and the ASD relay, they should be the same type.
    Otherwise, your problem may be lack of fuel pressure from either a bad pump, or a bad pressure regulator. An easy way to check is to rent a fuel pressure test kit from a place like autozone and test fuel pressure at the fuel fail by the TB.
  4. kdryan
    kdryan Member
    76
    Oct 11, 2015
    Ram Year:
    1998
    Engine:
    5.2
    Got a new relay since there are about a dozen of the same thing on the truck. I figured if no joy, I would have a spare. No joy... Don't hear the fuel pump...
Share This Page
