Exhaust Mainfolds
bigcrew
Hello Benny, I'm looking to replace the exhaust manifolds on my 2015 Ram (Hemi Tick). Can you advise me on the best OEM replacement? I'd like to do both manifolds, gaskets and bolts with something reliable.
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Hi,
Here are links to the OE replacement parts
x4 https://parts.allmoparparts.com/oem-parts/mopar-hex-flange-head-bolt-mounting-6036734aa
x4 https://parts.allmoparparts.com/oem-parts/mopar-u-nut-mounting-6036684aa
x9 https://parts.allmoparparts.com/oem-parts/mopar-double-ended-stud-mounting-6510141aa
X9https://parts.allmoparparts.com/oem-parts/mopar-hex-flange-head-bolt-mounting-6510140aa
X9 https://parts.allmoparparts.com/oem-parts/mopar-hex-flange-lock-nut-mounting-6505316aa
Some parts are on a 30 day backorder so we will need to allow that please. I will send you a code you can you as well.
Please let me know if you have any questions.
Thanks,
-Benny
bigcrew
bigcrew
Thanks Cap’n
Ron Boggio
Sumerduck, VA
5.7l
If you are replacing the manifolds, and if money is not the primary motivator I would suggest investigating "shorty headers". The bolt issue is resolved and the shorty's are the same dimensions meaning the stock exhaust i.e. the y pipe bolts directly to the headers with no modifications. The delta between the set of headers and the set of OE manifolds is nominal.
bigcrew
bigcrew
Ron,
And suggestions on shorty headers? I’m looking at AFE shorty headers.
