Extra plug in steering wheel
Buckeye2019
2018 Cummins
Anyone know what this plug goes to
Hemi395
Cape Cod MA
Does it have the audio controls on the back of the steering wheel? Bluetooth? 8 Speed "Gear+/-" buttons? Might be for one of those...
Buckeye2019
Buckeye2019
2018 Cummins
It has all the buttons front and rear....... I'm thinking it might be for heated steering wheel
Hemi395
Cape Cod MA
That might be it. Can't tell from the pic but is it a fairly heavy guage wire?
Avgas
2015 Express
3.6 Pentastar
Yes, that is for the heater, you might have a spare plug on the column side as well, but you would need a new clockspring to connect them.
Buckeye2019
Buckeye2019
2018 Cummins
So if I get the new clock spring it will work. Cause out of te doner truck I got the steering wheel heater switch.
Avgas
2015 Express
3.6 Pentastar
You will need to verify that you have the matching unused plug in your truck. After you remove your steering wheel, you can look for a spare plug plugged up to a green dummy plug.
Buckeye2019
Buckeye2019
2018 Cummins
Ok and if I do then I will need the clock spring and it will work? Nothing else did you do this to your truck?
Avgas
2015 Express
3.6 Pentastar
Yes, I dont believe a dealer flash is required. No I have not done it.
