- Dec 7, 2020
- 6,891
- 17,445
- Location
- Minneapolis, MN
- 2017 2500 Laramie Crew Cab
- 6.4L HEMI
Running any hydraulic oil for long periods above 140 degrees F = bad. That's all there's to it. Any Lubrication Engineer will tell us that (like myself).
For each 20 degrees above 140, oil oxidation life is cut by HALF (whatever it happens to be in the first place). So, if we run bulk transmission oil at 180F, you need to cut the oil change interval. It seems obvious to me the oil is not "lifetime" or any other time other than UOA would indicate. I can tell you my oil looked and smelled like **** @ 35k miles / 4 years. I have just a 66RFE, but it doesn't matter to oil oxidation life.
The worst enemy of transmission oil is heat. Period. Nobody in their right mind would run hydraulic oil in other equipment @ 180F.
