Hemi395
- Mar 18, 2013
- 8,989
- 15,671
- Location
- Cape Cod MA
- 2013
- 5.7 Hemi
If you're pulling the pan might want to check to see if Lubelocker makes a gasket for the ZF pan
I'd look the cheap pan over really close,and check the gasket out.Your local dealer should have a gasket in stock if you need one.Tranny gaskets aren't where you want to cheap out on.
No Lubelocker for the ZF that I can find.
I'll throw a little locktite on them when I reinstall. You would think other people would be having issues with pan bolts backing off as well but maybe its just my luck. I dont think I've ever pulled a pan and had it seal the first try.
Somethings up with the way you're doing things or the cheap parts you're using. Aluminium transmission case /steel bolts ,don't need thread locker.Steel bolts into aluminium don't generally require thread locker,throw the cheap parts away you're using and get the proper pan and gasket,last thing you want is your cheap **** costing you a tranny. Transmission pans and gaskets are not where you want to save money
I ordered a factory gasket today. I still have the bolts from the OEM pan, so maybe I will pull all the new bolts and reuse the old ones. Could be something slightly off about them. I did notice the OEM bolts have what look like some sealer/loctite but is likely just corrosion from the steel on aluminum contact. The pan was identical to the factory one down to the magnets and filter openings. If the OEM gasket and bolts dont fix it I guess I have no choice but to buy another pan. Plenty of people have used aftermarket pans with no issue though so I'll start with hardware.
