Front Diff swap details and info
Bandit517
That Trials Guy
Wauseon, OH
I've been planning a 3.92 gear swap for a while. 3.21's and 35's don't agree too well. I've been trying to research the specifics of the swap before I buy stuff and tear my truck apart. Even with searching the forum it seems to be a mix bag of information.
What all is required for a 2010 diff swap in a 2016? I've read that the carriers have a different passenger mount, and possibly the motor mount is different? pinion flange? CV axles? I found a walk thru from another member a while back but since the forum update I can't seem to find it again.
I found a 2010 local to me at a u-pull yard that has 3.92 gears according to the build sheet. And a factory LSD (Not the best in the world but better than my open rear diff) I was figuring on pulling the front diff and complete rear axle to swap into mine as that seems to be the better all around option. I could order gears and a trutrac for my rear diff. So the rear isn't the big issue. I'm just wanting to verify and consolidate information for the front diff into one area that way I know what I need to get and also anyone wanting to do this in the future.
crazykid1994
If you can find a 3.92 diff from a 2012 and newer it’s a straight swap in. 100%. No modifications. Otherwise you have to modify engine mounts and diff brackets. There’s a whole thread somewhere on here about it.
Bandit517
Bandit517
That Trials Guy
Wauseon, OH
That's the thing, I remember the thread. But I can't find it again, and I don't remember what all is needed. I'd like to pull everything in one shot if possible. Not something that's happening tomorrow but I'd like to get all my ducks in a row for it. In the meantime I'm still looking for a 12+ because I knew that it was a bolt in swap.
fernandok
Toronto, ON
HEMI 5.7L
Can you open up the diffs and swap the guts from the 2010 diff into your 2016?
DILLIGAF
Canada
but then you still have a POS gen 4 front diff that has a 500$ output shaft replacement cost when it goes bad.
Do the Gen 3 swap I posted my DIY when I did it. and there 2 other DIY threads about it, just search the forum
Seriously do 456s gears.
Bandit517
Bandit517
That Trials Guy
Wauseon, OH
I've about lost my mind with the new forum and lost features. I forgot who posted the thread and soon as you commented I clicked your profile trying to search your threads and it only shows comments. 20 pages worth going back to May 11, 2020
How are 4.56's with 35's on the highway? I don't have any plans to go to a bigger tire. My truck won't fit in the garage then.
Administrator
Before considering 4.56 gears that the ZF 8 spd in your truck first gear is 4.71 where as the RFE 6 spd first gear is 3.0, I believe DILLIGAF truck has a 6spd. Even 2nd gear in the ZF is lower at 3.23. The difference at highway speeds will be 400-500 rpms higher with 4:56. With having more gears the ZF ratio spacing is better and doesn't have the large 3-4 jump like the RFE does.
crazykid1994
I have the 8 speed with 3.92 gears. 4.56 gears are to much in my opinion unless you are running 37s or larger. I have 35s and at 80 mph run about 2100 rpm. For the 5 or 6spd guys 4.56 is great
fernandok
Toronto, ON
HEMI 5.7L
Any info on this? I cant find it via search bar.
DILLIGAF
Canada
