Looked all along the path from the filter. Nothing right up to the front. Seems to be from somewhere around the idler pulley.Start at your fuel filter and trace forward. Recommend in the dark with a flashlight so you can see the light reflect off the wet.
Have you tried starting it and look for spray?
I will check that. I would prefer that to something worse.Are you sure it's diesel fuel and not oil from your AC compressor?
Thanks for that but I am in AZ so need the air.I had the same leak about a year ago and it was the AC compressor seal. The oil looks and feels like good ol diesel fuel. Never use the air so I ignored it and it eventually stopped. Good luck
If I ever got that far south, I might have to rethink the AC too. Up here in the north the window works well enough.Thanks for that but I am in AZ so need the air.
