Wyatt Blakeley
Hey everyone. Been doing research for a while and just had a "small" thought. I decided that eventually I'm going to try and re gear over the course of this summer. I've found out that in the models above 2011 it is that the largest gear you can fit in the front differential is 4.56. I've been trying to decide if 38 or even 40 inch tires would be okay with this gearing? I don't do any offroading or any type of towing if that helps with anything. Any opinion helps, thanks.
