Has anyone solved the USB to center console problem yet?
Informal
SoCal
2015 Sport 4x4
Hi all, new member here.
I was combing through the forum, and didn't see an answer, so I apologize if I missed it.
I have a 2013 Ram 1500 Express which came with the non upgraded Stereo (with XM/Sirus)
I swapped out the radio with a Pioneer double din unit, while I was removing the stock radio, I saw the usb plug that went from the back of the radio, to the center console.. The cable end to the radio was a USB mini male.. So I found a female mini to USB A (standard) adapter... It lights up the console USB, but the screen on my Pioneer says "Incompatible USB"
Did Dodge use some type of Proprietary USB? Anything else I could be missing? I have tried two other adapters.. all the same result.
Would really like to have my console USB useable... Any ideas?
Thanks!
jeepguy_1980
5.7L
It's a USB hub, your radio probably only accepts one device.
Sent from my SCH-I545 using Tapatalk
Informal
Informal
SoCal
2015 Sport 4x4
Ahh, so it's not just a single run USB to the console? It hits a harness and is used for other USB devices?
I guess I'm looking at getting a panel mount USB like this one
USB Adapter A-A, Black - ECF504B-UAA
and installing it in the console, anyone know how difficult access is to the backside of the console?
Thanks for your reply jeepguy.
jeepguy_1980
5.7L
You could try a USB that doesn't have a USB port, SD reader, and auxiliary jack.
Informal
Informal
SoCal
2015 Sport 4x4
Sorry.. I don't understand, are you talking about another port already on the truck?
jeepguy_1980
5.7L
Some trucks have just the port and no SD reader. That panel may work.
Informal
Informal
SoCal
2015 Sport 4x4
Mine has just the port and aux input
jeepguy_1980
5.7L
You could open it up and wire the cable directly to the USB port. And then wire the auction jack directly to the aux in jack.
Informal
Informal
SoCal
2015 Sport 4x4
Thats what I'm thinking, Perusing forums.. I haven't seen anyone who has figured out the easy access point, to get behind the panel.
Maybe I'll just go yank it out and have a look. :superhack:
Informal
Informal
SoCal
2015 Sport 4x4
Thought I would update this, in case another poor soul is seeking info on getting the center console USB to work with an aftermarket head unit.
My first move was to try a mini to standard adapter... no go, says "Incompatible USB"
My next move was to cut the cable that leads to the center console (it's under the drivers seat) oddly enough, when I cut it... it was 4 cables Red- Black-White-Green (same as any Standard USB... So I figured Dodge must have reversed the data lines for some weird proprietary thing.. So I hardwired the cable and switched the data+ and data- wire...Still no go... then I got flat out reckless and tried dozens of different orientations.. NOTHING works.. I'll search for a few more months for an answer to this mystery..Then just run a new line up to the console.
I can't be the only 2013 with an aftermarket HU who wants his center console USB to work.. Can I? :think:
Informal
Informal
SoCal
2015 Sport 4x4
gmzvip23
2k12
Thanks for the link, I just ordered one... Have to say I'm fairly pissed off at the guy I spoke with at Metra.... Who claimed they made no such cable. :argue:
tell us if it works man. Id like to keep my ipod sperate from my phone.
RamExpress
yeah let us know! that way I don't have to pull mine back out if it doesn't work :party36:
Informal
Informal
SoCal
2015 Sport 4x4
Should arrive today or tomorrow, I'll let you know when it's installed.
Informal
Informal
SoCal
2015 Sport 4x4
Incompatible USB
Same as the last two adapters I tried...
Would be nice if they tried these things before they advertise them as a fix "For those that want to retain OE USB connectivity"
I give up on trying to make this work, just gonna look for a panel mount USB and re-do the whole run.
RamExpress
well that sucks!
I think the "solution" is to do a single run and then splice it into the current plug in the panel. Remove the rest of the wire "hub" part that might be causing the issue. That way it remains factory looking but functions with aftermarket radio. That's gonna be my plan next spring when i get some time to tear it all apart.
Informal
Informal
SoCal
2015 Sport 4x4
well that sucks!
I already tried this... I put a fresh cable right up to the USB block, The business end of the plug seems to be where the problem lies.
It seems most Car makers disregarded what the "U" in USB stands for..
UNIVERSAL !!!!!!!
Amabate
I'm trying to figure this out as well. The only thing that I think may be an issue is if the mini connector has the ID shorted to ground (or visa versa) in the adapter and the HU doesn't like it. I'm going to try plugging a cable from my stock usb to a phone with a mini B connector and see if the stock stereo still see's the device (it should). If not then the issue isn't with the stock cable it's in the actual connector.
Informal
Informal
SoCal
2015 Sport 4x4
I agree, I think the problem lies in the connector.. I actually cut the wires and rewired in every imaginable config.. Nothing
Island-cowboy
