Heater blower motor - stopped working
Discussion in 'Tech Info' started by HeavyD, Dec 10, 2016.
  1. HeavyD
    HeavyD Senior Member
    1,128
    237
    Feb 21, 2015
    Medicine Hat, Alberta - Canada
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    Ok was driving & doing errands today, blower motor working good - no problems.
    Then after dropping stuff at home, got back in the truck & blower motor does not do anything.
    Checked the #4 fuse, even swapped it with another & still nothing.
    Im guessing its mot the switch or resistor.
    So is the motor gone??
    Its stupid cold outside so did not check power at the motor, so don't know it has power or not.
  2. Bigguy45
    Bigguy45 Junior Member
    14
    Nov 16, 2016
    Bedford, va
    Ram Year:
    2003
    Engine:
    I could be the motor is bad. I also had one truck where the ignition switch had melted some causing the blower not to work.
  3. HeavyD
    1,128
    237
    Feb 21, 2015
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    Ok had the motor out & bearings are bad not it still works on bench, it just stops fast after power is off.
    so I hooked it back to the truck plug & it only works when I add power to the plug.
    So I think this Is a burnt ignition switch.
    Is it hard to replace the ignition switch
    I will also replace the fan since it on the out.
  4. HeavyD
    1,128
    237
    Feb 21, 2015
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    found vid on y-tube, buying parts tomorrow.
  5. HeavyD
    1,128
    237
    Feb 21, 2015
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    Ignition switch & heater fan/motor.
    The switch was about what prices are on the net, but the heater motor was way more.
    [​IMG]
    [​IMG]
    [​IMG]
  6. HeavyD
    1,128
    237
    Feb 21, 2015
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    New ignition switch in & with old fan it works.
    Will be putting fan in yet today.
    [​IMG]
    [​IMG]
  7. HeavyD
    1,128
    237
    Feb 21, 2015
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    All back together, the ignition switch is tight but works good.
    [​IMG]
    [​IMG]
    [​IMG]
  8. Bigguy45
    14
    Nov 16, 2016
    Bedford, va
    Ram Year:
    2003
    Engine:
    Glad to hear it
  9. snuffysmiff
    snuffysmiff Junior Member
    Nov 6, 2016
    Ram Year:
    Engine:
    Did the exact thing last month. Except I changed the motor, then the resistor, then the control unit, and finally, after the dealer diagnosed it, I changed the ign. switch. They wanted over 500, including diagnose, and the ign. cable, which it didn't need.
  10. Browns06
    Browns06 Junior Member
    Jan 22, 2017
    Ram Year:
    2006
    Engine:
    Ignition switch
    I had my blower motor go out then I replaced the fan motor and it is working but got a immediate. Dash light for engine could the ignition switch be bad too. It is giving me a p750 code and can't reset it.
Share This Page
