Hitting Fender
HemiBabe
DFW
I have the 2/4.5 spindle drop, 22 in rims, and brand new 305/40/22 tires. My wheels are sticking out past the fender a little, therefore causing my tires to hit the front fender lips on the highway or any big dip in the road. It is gettin on my last nerve and tearin up my fender lips and I dont want to mess up my new tires. This pic is lookin at the drivers side front tire
Anyone else here have this problem?? How can I fix it?? New rims with a different backspacing? Roll the fenders? I have no clue what to do but I am gettin sick of always being paranoid on the highway everytime I see a dip or bump and suckin cusion LOL. Please help guys!
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
Wow! Eventually you may end up buckling the fender quarter.
Well you either raise the body, or lower the front axle. I would try 1/4 inch level. It wouldn't be off so much That it wouldn't look out of place. But I would start raising the ass end if that were not enough. In increments, with the front. If needed, You could ****can the tires and go with a lower profile, Idea Was dan's btw.Jmho.
The Assassin
B-more careful, Murderland
Are the tires the same size as what you had? If I recall, the wheels are new right? Rolling the fenders isn't going to make a difference. You need a more narrow tire, or a wheel with less back spacing. Perhaps even a tire with a smaller side wall.
HemiBabe
HemiBabe
DFW
I got the rims a few months back from Jeremy. I had em on there before I dropped it, and ever since then it hits. 20s would look goofy i think. What backspacing on a rim would make it work? I think the tires are too wide + wide rims. really sucks
nim81
Fredericktown, MO
5.7L
Maybe some new bumpstops would help
Sent from iPhone-taptalk
HemiBabe
HemiBabe
DFW
I bought some diff bump stops when i lowered it, they are smaller than OEM ones, maybe put oem ones back on? but then wouldnt it be hittin alllll the time?
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
It's possible and this would make for an unsafe/rough ride.
HemiBabe
HemiBabe
DFW
Right, so what do yall think I can do? Get diff rims w/ a diff backspacing to pull in inwards? Go back to 20s? I just want it to not hit anymore
HemiBabe
HemiBabe
DFW
Ok, how can I find out the backspacing on my rims?
pavester
texas
new rims is going to be the only way the problem will be fixed. thats why jeremy had his rear end shortened on his rear
truckin151
2013 sport
I have heard quite a few people having issues with a 305/xx/xx tire rubbing up front. Could be causing you issue too. Do you have a spindle drop or shorter springs up front?
HemiBabe
HemiBabe
DFW
Well, I'd like to stick w/ 22s and a 5 spoke rim like what I have... what do u recommend?
Really? I have the 2" drop spindles with stock springs in the front...
HemiBabe
HemiBabe
DFW
Anyone know how to measure backspacing? I need to calculate what size backspacing i need
rocket
connecticut
was 2006
was a HEMI 5.7
The wheel is measured across the rear diameter of the rim, the distance from the back side of the center hole too the rim is your ''backspace. I would use a simple yard stick too determine the this, simply lay it across the wheel and then measure to the center hub, Thats how I did mine.
ramhunter9
P-Star Jeep Wrangler
Lift it and throw on some 37's
Sorry .... just trying to make you smile as I know nothing about the low low's
HemiBabe
HemiBabe
DFW
Hahahaha!! :D I'm really wishin I had went ahead and gotten a 4x4 like I originally wanted. I was seriously debating with myself yesterday to trade it in and get a Chally or 4th gen 4x4, but I don't want payments. Or, find someone w/ a 4x4 and trade them.... But I know once I get this figured out, I might start likin the truck again.
HemiBabe
HemiBabe
DFW
Alright, awesome Kyle thank you! ... Does anyone know what backspacing I need to shoot for to make those rims work?
rocket
connecticut
was 2006
was a HEMI 5.7
You may end up with a rub on the a-frame/ wheel well; if you get too much in the backspacing dept.
