ncgrl1
- Apr 18, 2012
- 209
- 85
- Location
- Cajah’s Mountain NC
- 2020 RAM LongHorn 4x4
- 3.0 EcoDiesel
What kind of money does it take total to get this to work?
Finally. All working
Should there be a temp indication other than the outside air and the slider?
No not that I know of. If you are not on the climate control screen and you adjust the temp, you should get a box at the top of the screen that shows the temp that you are setting it to.
Has anyone tested the voice commands to set the temperature?
Well, I have successfully pulled off a single Zone ATC bezel mod after about 8 hrs of work and repairing a partially damaged board. Very difficult to do without a $1000+ SMD repair station, but it can be done.
I would give this a 9 or 10 on the difficulty scale because of the small size of the components/traces.
Big thanks to @00R/T for some great notes and pointers to pull it off!
M² Mods - From my non Flammable S7!
