Ram06_1500
i have a 2006 ram 1500 with 9.25 rear. Had stock 3:55 open gears. Spider gears chewed up so I decided to rebuild. I purchased everything at Moe’s performance. 4:10 gears with master rebuild and trutrac LSD.
I’ve never rebuild a differential and was aware of its intricacies but all shops were closed due to the pandemic. I followed the guide lines as far as factory specs. Should factory specs be called when upgrading to 4:10 gears from 3:55?
I was told by Moe’s that I should be able to get away with reusing shim. Which I did. I had the pinion depth set at 15in lbs with new crush sleeve. I’ve since tried backlashing the gears but cannot get it lower than .12. Factory calls for .05-.07. I’ve tried adjusting and any tighter it locks up. So I’m assuming pinion depth might be off. There’s really no where to turn to as far as setting pinion depth with my setup. I’ve tried YouTube but got nowhere. Can anyone shed any light and possibly help out?
