I think I may have made a mistake..
HLram
2012 and 2007
Hemi 5.7 in both
The one in the link is a single in and out. You will need a single in/ DUAL out.
Cowboy345
Kentucky
HLram
2012 and 2007
Hemi 5.7 in both
Yep, that's probably the one you need. Especially if it is on Moe's site. It should fit, Matt wouldn't sell it to you if it didn't.
HLram
2012 and 2007
Hemi 5.7 in both
Yes but that will have to have pipe added and welded in, however the mufflex will just bolt in.
Mufflex 14" Magnaflow Dual Exhaust 09-Up Ram 1500 5.7L Hemi
Yeah, that's what I went with, too. I had a small leak, probably because I didn't use air tools to tighten it or sealant. I took it to an exhaust shop and they welded it up nice for me. No leaky now. If you get pipe added, make sure they de-burr the pieces. I am **** about that for some reason, LOL.
HLram
2012 and 2007
Hemi 5.7 in both
yes it is. May as well get that too. But the pipe Cowboy was talking about is just exhaust tubing to make the muffler reach the tailpipes. But I would certainly add the Y pipe if I was doing the weld in muffler.
Vancouver604
Vancouver604
Hemi 5.7L V8
Anything else you would add?
Cowboy345
Kentucky
HLram
2012 and 2007
Hemi 5.7 in both
Hemifever tune, longtube headers........hahaha. Seriously on the Hemifever for sure. Really opens the truck up big time. But if you are on a tighter budget, then a 180 degree thermostat, catch can for sure!!!!, ported TB, CAI......
HLram
2012 and 2007
Hemi 5.7 in both
I don't know what size the tailpipes are. Sorry. I like the longer tips that from the side view of the truck you can't see the tailpipe. All you can see is the tip. Looks really good. JJ had a picture on a thread one time that had those bigger, longer tips. And they were sweet.
2013Ram1500
2013 CC 1500 4x4
I see the 180 thermostat everywhere, but I don't know what it does. Could you or someone explain it to me? Thanks
Sacredsouls
The 180 thermostat opens at 180 and allows the cooler water to flow thru the motor keeping your truck at a cooler operating temp. Think of it as a heat operated switch. Under 180 it is closed to keep the water in the motor to warm up, at 180 it opens allowing the hot water in the radiator to cool and the cool water in the motor.
2013Ram1500
2013 CC 1500 4x4
Thank you!
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
The stock tail pipes are a 2 1/4" inlet. Nobody makes a bolt on 5" tips for the stock tail pipes except for Mufflex, but they are on the short side. If you end up going with 5" MBRP tips, then you will need to buy or fabricate some 2.25" to 4" adapters because their 5" tips have a 4" inlet. In the end, this is not a cheap upgrade. You will also have to cut off your resonators and have the new setup welded in.
If you are going to take it that far, I would just go with a complete catback system instead that comes standard with bolt on 5" tips. Then you get the muffler, all new stainless piping, new tips, and it all clamps on easily to avoid having to weld on your new truck. It also deletes the resonators and comes with larger 2.5" piping off the muffler.
metalfab
Vancouver, Canada
2012 RAM CrewCab ST
I'm going here to get my muffler here Quiet Muffler They are in Burnaby on Kingsway and Salisbury, have been around for a long time and they are local. I phoned and a month ago and their prices seem good. I don't have price details on me but give them a call.
