Ignition switch trim ring
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
Any of you guys removed the trim ring around the fobik or starter button? Mine spins freely but there isn't really enough slop in the fit to try and pop it off. I don't wanna break it by trying to pry it if that's not the intended way.
I have a small piece of silver carbon fiber that I want to wrap it with.
Sent from my SM-G900V using Tapatalk
quietpeen
2021 TRX
Hellcat
I have the push button start and if you take the panel off that is below the steering wheel the trim ring is attached to that and the push button is separate. So I believe once that is done you could pop the trim ring out from behind the panel
HEMI_Finn
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
Thanks. I'll have to give it a better look tomorrow. Gotta damn near be a contortionist to get under there with a floor console!
quietpeen
2021 TRX
Hellcat
It's really not that bad. I have the center console too. From sitting on a stool on the drivers side there are two screws to take out on the bottom, then it's all just clips holding it on I'm pretty sure
HEMI_Finn
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
Fingers crossed!
deangtp
I took mine off and painted it
HEMI_Finn
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
Ok, did you get yours off the way quietpeen described?
deangtp
Yep. Two screws on the bottom. Pull straight towards the seat and the clips will release. After that. You'll see exactly what needs to happen for it to come off
HEMI_Finn
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
Well, I got the panel off and the trim ring out with no problem. Unfortunately, the way that ring looked wrapped in silver carbon fiber just didn't look like I had envisioned, so I peeled it off and I'm back to thinking again.
I had originally thought painting it bright red, because it would really pop against the black dash. I may go back to that.
Ram Man
FL
2013 Sport
provide pics of what you do! or if anyone else has painted theirs
HEMI_Finn
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
Lol, as long as it turns out good, sure!
quietpeen
2021 TRX
Hellcat
did it not look good because the ring is for the most part is thin so you couldn't really get the carbon fiber affect?
HEMI_Finn
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
I think that's what it was, yes. I've got plenty of time, I'll figure out something.
EagleChief
Oklahoma
2014 Big Horn
Paint would probably be your best option. Now that you've brought it up, I might have to try it.
quietpeen
2021 TRX
Hellcat
I will probably get the same results, but i'm kinda wanting to try to wrap it in the black carbon fiber that I have just to see
HEMI_Finn
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
I'm thinking paint only because I didn't see anything else in a vinyl wrap type of medium. Too bad tritium is so expensive!
HEMI_Finn
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
The piece I used was 3m di-noc. It seemed kinda thick. Maybe something thinner and a smaller pattern would work.
quietpeen
2021 TRX
Hellcat
dang i have the 3m di-noc too....doesn't hurt to try....they are scrap pieces anyway
HEMI_Finn
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
Scrap is what I used too. It's too bad because I really like the look and pattern of the di-noc.
quietpeen
2021 TRX
Hellcat
I might try it tonight, not expecting anything since i know your results. I will post pics of the good or bad lol
