Info on rear slider switch
Vncnz
Has anyone ever got this switch to work anything other than the Window I want it to work my train horns
Ricks Ram
I installed the power slider in my 14 and it's jut a simple 5 pin reverse polarity switch. Positive and negative in positive and negative out and an illumination wire. I would assume your truck would be similar. You would just need to figure out Wich pins are for which wires. In would be simple to if your trucks switch is similar to the newer modles but would most likely only blow the horn if you pushed it in one direction.
Vncnz
Vncnz
Got it there's three pins on one side top pin positive middle is Neg and the third is a negative out to what're u want! [emoji41]
