Information on premium cluster upgrade
R.L.K.
R.L.K.
Bristol , Tn.
Bump
Sent from my SM-G900V using Tapatalk
R.L.K.
R.L.K.
Bristol , Tn.
Odin
Arizona aka HELL
Hemi 6.4L
This is a very informative thread and I'm glad I stumbled upon it as I'm starting to look at several different interior upgrades now. Was wondering if you could help me out RLK?
I used to have a 2013 RAM 1500 and at the time purchased a 13 7" EVIC to put in it and then traded it in '15 without doing the cluster upgrade due to not have a secondary vehicle while waiting for the cluster with correct mileage to come back. I want mileage, idle hours, and drive hrs to be as exact as possible.
Fast forward, I believe there is now a shop in the city I live which can do the programming same day. So here are my questions...
1) I have a 2015 2500 Tradesman with 5.0 Uconnect radio. Will the cluster work?
2) I have read on other threads the TPMS is an issue... However, I already got a TPMS issue from having larger tires which require less air. So, if the TPMS issue presents itself, do you think it would be possible to just reprogram the TPMS with current air pressure or is it the actual TPMS module which would need to be replaced?
I'll eventually be upgrading the 5.0 Uconnect to 8.4 using Infotainment's upgrade kit, so I'd there was to be a conflict with the cluster a d my current radio it would only be for a short time.
Appreciate the help!
R.L.K.
R.L.K.
Bristol , Tn.
In an attempt to answer your Questions Sir .
#1 YES the 13 cluster will work in your 15 2500 BUT more than likely the TPMS will not work.
#2 if the TPMS does not work ( like I think it won't )
To my understanding the RF module in your truck mounted being the back seat ( I think ) can not communicate with the 13 cluster .
I haven't seen anyone fix this .
I believe the tpms sensors and the RF module would need to be changed .
Not sure this would work though.
Easier to just purchase a 15 cluster and sell the 13 to recoup some loss .
Odin
Arizona aka HELL
Hemi 6.4L
Appreciate the quick response!
I actually did a search prior to posting and couldn't find any 14-17 clusters for less than $550... Just did a search again and 1 was freshly posted on eBay for $300 after shipping. Just snagged it up!
Hopefully the place here in town can do the programming. I don't really wanna send it out as numbers won't be 100% accurate which I'd like them to be.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
If you can find a deal on an 8.4 radio, its likely cheaper to piece the upgrade parts than to buy them all at once from them. We have you covered on the harness when your ready.
M² Mods - From my non Flammable S7!
Odin
Arizona aka HELL
Hemi 6.4L
Only reason I'm looking at doing theirs is because it comes preprogrammed so there won't be any activation/sales codes required. I only saw the recent thread here on the forum (I'm not as active as I should be) so haven't had a chance to look through it to see how all that stuff works if you buy the radio without the programming.
Mpgrimm2
Preferred Vendor
SC
5.7L
It's either free at the dealer (with original vin) to get the unlock code, or you can get it for $10-$20 online within a few minutes.
Key is to make sure you get a Ram compatible RA4 vp4-NA radio (or Ra3 Vp3-NA). I have a dedicated thread with ram RA4 vp4-NA part numbers. Linked in post 3 of the conversion thread.
Ricks Ram
As stated there is no activation or sales codes needed. All you you need to do is get the 4 digit unlock code which is usually available at the dealer as long as you have the Vin# of the truck it came out of or you can purchase the code on line with the serial# and part# for around 20.00. You can buy the radios several places like car-part.com and eBay. I recommend reading the posts and catching up on the information before you purchase your radio. You can possibly save a lot of money.
Sent from my SCH-I545 using Tapatalk
R.L.K.
R.L.K.
Bristol , Tn.
I am about to upgrade my 2015 to the 7" EVIC cluster.. Are we 100% certain that a 2013 or 2014 cluster has TPMS issues? Is that all? I would buy a brand new one from all mopar parts but I can't seem to find the section with the clusters... Anyone have a link?
To my knowledge you can purchase a new cluster from Benny @ allmoparparts.com
You'll need to have a vin # from a Ram truck that came from the factory with a 7" premium cluster.
Maybe you can just have a p/n not sure .
In my OP I gave the p/n to a 2016 cluster that will work in your truck.
But I'm pretty sure Benny will want a vin# of a vehicle that had a 7" premium cluster from the factory.
You could hit some dealerships used lots and jot down a vin on a Ram that has a premium cluster .
Hope this helps !
R.L.K.
R.L.K.
Bristol , Tn.
Bump
darkkyn
Olympia, WA
2018 Ram 1500 Rebel
5.7L
Just completed my Rebel lensed upgrade, along with the 8.4 radio using M2Mods harness. It all went pretty well. Except now I want to try and match the red of the Rebel lens around the rest of my cab. 1/2 thinking painting (airbrushing) might be the way to go, but does anyone know the part numbers for the other Rebel pieces?
R.L.K.
R.L.K.
Bristol , Tn.
Some folks have done this via painting trim , some have done this with tape , others with a professional look using .... sorry I just can not remember what it's called ....
Search automotive trim covers on Google or here ...
kad
Hudson Valley, NY
5.7L HEMI
Infotainment is now selling the clusters, programing included. As usual, they are overpriced, but only for the Gas version (About $200-300 over eBay). For the Diesel version they are on par with eBay, the odd part being that they are selling both for the same price, $800. The benefit for the higher price being, I guess, a warranty of some sort.
https://www.infotainment.com/collec...nstrument-panel-cluster?variant=8331411161124
-K
kad
Hudson Valley, NY
5.7L HEMI
And... they figured it out. The Diesel cluster is now more expensive than the gas one on their site.
-K
GatheredEarth
Alabama
Upgrading my 2015 express to a premium cluster was some of the best money i've spent on any mod. Replacing the steering wheel to use audio controls and upgrading to a nicer factory radio is the next thing on my to do list.
Thelegendl23
Where did you buy it?
GatheredEarth
Alabama
I didn’t have it flashed. The one I bought had a few more miles than my truck and I just waited until it was the same before I swapped it. The hours prob aren’t the same though.
