- Nov 3, 2011
- 8,366
- 7,529
- Location
- Houston, Texas
- 2017
- Hemi 5.7
Hopefully @kad can get you guys squared away
Yup. Actually the design work is (hopefully) done. After many cardboard prototypes and fittings I'm currently in the middle of making a set in steel. Got the major drilling and cutting work done Wednesday, I was going to do the final grinding, filing, etc last night but the weather wasn't conductive to doing anything but sitting inside in the air conditioning. 90F and near 100% humidity isn't my thing. With any luck I'll be able to get back to working on them on Saturday.
Sneak peek:
-K
Well heck. I went an bought a steel angle bar and was going to chop up my own. I will definitely buy a pair from you.
Any idea what the unit of measurement is in the previous CAD diagram? (Or the measurements of yours) No one around here is going to be able to make something like that but I can chop something up if I know I have enough material.I'm flattered, thank you, but I do not intend to make them for sale. Quite frankly they are too much work and I do not have the means to conduct engineering safety tests, etc. My intent is to release the pattern for those who want to make their own for personal use with the caveat that I am not responsible for any damage, injuries, etc that may occur from using the design. If I ever find a machine shop willing to do them from the plan for a reasonable price I may reconsider, but so far I've had no luck with that.
-K
Secondly, I'm not concerned about the safety side of it; it's mainly for looks. If you do end up making some send me a PM or something... under the table LMAO!
TI posted my CAD model on grabcad.com in .stp format for anyone would like to try making a set. It's a 3D model only, you'll need to produce your own drawings with dimensions, using your own CAD software.
Just FYI, you don’t need all those fancy angles that Ken has and you incorporated into your mo
The subject of the angles is the one point that JB and I differ on regarding these brackets.
-K
just put rebel tow rings on my big horn this weekend. have been wanting to add View attachment 130001 View attachment 130002 hooks when I found a set of rebel hooks I couldn't pass them up. Like to be a little different from everyone else this fit the bill.
What would be your reason for attaching them with the openings facing inward?Fitment test is done. The fit is good and the hooks end up where I wanted them, centered both up/down and left/right in the large portion of the opening. The hook I grabbed for the test fit ended up facing out, as the factory installed ones do, but I may switch them around and face the openings inward when I do the final assembly, I haven't decided yet. Now I just need to get everything painted (the hooks I bought used, so everything needs paint).
-K
Go bold! Paint them fire engine red!
The reason the openings face out is so that if you're using a v shaped setup to be pulled out, it pulls the straps towards the center, so there's a higher chance of them slipping off if your openings are toward the middle.
Wire brushed and ready for primer.
-K
Where did you get them made and how much did it cost?
Any luck on finishing?I made them myself. It cost about $5 for 2ft of 2.5" mild steel angle from the local metal supply house and about 5-6 hours of labor over two days. That's not counting all the time designing them and testing prototypes made of softer materials. I'll be posting the plans once I finish cleaning them up.
-K
