Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
The wire that feeds the 12v power outlet is where I tapped into for mine. I ran the wire in under the edge of the overhead console, across inside the headliner, down the a pillar and under the dash to the area behind the outlet.
I pulled from the mirror power as well. The only issue is that it’s switched 12v so u loose parking mode and security. Don’t forget you need a 5v converter.
